unable to use data
moeghafoor
Hi since yesterday Oct 11, I am unable to use any data. Can you fix the issue as the issue still present today on Oct 12
@moeghafoor
What is the plan you are on?
When is your next renewal date?
Rastin
You wouldn't be in BC by any chance? Read a few other post about slow or no speed and there all there. If you change to 3g or the slowest your phone can go you should have usable data and hopefully what ever problems there having out there will get fixed.
Rastin
We can't fix anything. Only customers here. If what Susan suggested did not help contact PM using the orange text bubble. Type in customers service agent or use the link below
Sansan
@moeghafoor  hi, first did you sign into your account to verify the account status?
Things you can try. Turn airplane mode on and off.
Reset phone networks.
If non of those works, what type of phone you have?
