unable to call out
CallaLily
Have not been able to have incoming calls or outgoing for the last 3 days
2 REPLIES 2
@CallaLily
Check to see if there are any Telus outages in your area:
https://istheservicedowncanada.com/status/telus/map
dabr
@CallaLily   Is your account active and not suspended for any reason?
Try rebooting the phone, toggling airplane mode on/off.   Try setting the network mode to 3G/WCDMA.  You can  try putting your SIM in another unlocked phone and reboot and back to your phone and reboot.
If nothing is helping, then submit a ticket via chatbot and ask customer support to take a look at your account here:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html
If unable to submit a ticket, then send private message to CS_Agent here:  https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
