05-07-2019 11:40 AM - edited 01-05-2022 04:48 AM
Hi Public Mobile Community,
I am new. I have submitted online my PIN and mobile number from Petro-Canada Mobility yesterday. My Petro-Canada is still active with the number and has not yet been transferred to Public Mobile. I have sent a private message to moderator yesterday, 3 hours ago, and 23 minutes ago. How long does it usaully take to resolve my issue or at least reply and say anything? thank you
05-07-2019 07:04 PM - edited 05-07-2019 07:12 PM
My number has finally transferred to public mobile a couple of hours ago; I just used the PIN from Petro-Canada mobility. It just took longer than I expected. Because the "how to activate" article said it takes up to 2 hours to transfer. I just needed to patient as was suggested by one of you.
Thank you everyone on this thread for the prompt replys. I wished the moderators replied promptly like you all; at least say something like there could be a delay or anything at least. I still didn't get any replys from the moderators.
05-07-2019 06:51 PM - edited 05-07-2019 06:57 PM
@colincolincolin wrote:Hi Public Mobile Community,
Read my post about porting number from Petro-Canada Mobility and Speakout.
You need the IMEI # used on your Petro-Canada Mobility. Dial *#06# on your phone using Petro-Canada Mobility SIM card. Send another private message to moderator if you did not supply your IMEI #. Moderator wait time is 2 - 3 days.
05-07-2019 06:43 PM
You might need to use IMEI to port from Petro-can. Verify with them imei they have filed.
05-07-2019 11:43 AM
@colincolincolin It all depends on the volume so typical times range from a couple of hours to 48 hours.
05-07-2019 11:43 AM
@colincolincolin , moderator team response time is longer than normal at the moment. Please stay patient.
