text message
04-22-2015 05:03 PM - edited 01-04-2022 01:23 PM
08-07-2015 09:04 AM
At the moment with Public Mobile there is no way of accomplishing this. However, I do see it as a great idea you can add to our Public Lab?
Cheers!
08-07-2015 02:18 AM
Darn. Would be pretty Convenient if It could work
08-07-2015 02:06 AM
08-06-2015 03:28 PM
Just curious. How do you have a texting conversation using this, if Handset was not on hand, or Battery was dead? Just curious. Also, how do you use the MMS ability with this?
04-22-2015 10:17 PM
@north450 wrote:how do you send text message using computer
Few methods were already mentioned by other poster, one more method is you can go to your service providers desktop site, in public mobile's case you can you use telusmobility.com or Koodomobile.ca and look for an option to send a text
04-22-2015 07:43 PM
I'm currently having an conversation with google
04-22-2015 07:22 PM
04-22-2015 07:13 PM
Is that site txt thing, Can anyone from any carrier use it, or only certain carriers?
04-22-2015 07:12 PM
So, for example, I f I wanted to send a SMS text to you, I need to have an existing PM a/c, and just enter email, phone #, text and that's it? How would I send txt to other person? just curious. New
04-22-2015 07:09 PM - edited 04-22-2015 07:12 PM
You can text anyone, but the recipient has to be subscribed to a "text plan" with Public Mobile.
If the recipient does not have a text plan, he won't receive your message.
04-22-2015 07:04 PM
What I meant was, How does this service work exactly? Can you text anyone, and they receive that text like you sent it via handset?
04-22-2015 06:46 PM
When you send an email, in the address field, you put this : 5140001234@msg.telus.com
This works for Public Mobile and Telus.
04-22-2015 06:26 PM
How does this work exactly?
04-22-2015 05:29 PM
Are you looking to send a text message from your email to a Public Mobile number ?
If YES, use :
[10-digit phone number]@msg.telus.com
04-22-2015 05:11 PM
try this: http://www.textem.net/
