11-25-2020 08:05 PM - edited 01-05-2022 04:15 PM
Phone cannot load google maps, cannot access internet via DATA. I have been using PM for a few years. New problem. I have a lot of data available. Turned on and off airplane mode, turned on and off phone, cellular is toggled on, maps is on cellular, internet provider is on cellular, I reset the network settings, and someone beside me on PM has an older phone which is loading and working just fine.
11-25-2020 09:11 PM
@elenatfranklin wrote:Phone cannot load google maps, cannot access internet via DATA. I have been using PM for a few years. New problem. I have a lot of data available. Turned on and off airplane mode, turned on and off phone, cellular is toggled on, maps is on cellular, internet provider is on cellular, I reset the network settings, and someone beside me on PM has an older phone which is loading and working just fine.
Hi @elenatfranklin you may try this solution by @Jb456 https://productioncommunity.publicmobile.ca/t5/The-Lounge/Google-Maps-Offline/m-p/521992/highlight/t...
on Google maps you can download "offline maps" and still get the turn by turn talking instructions. It's the same thing except you won't get real time traffic updates since it's not on data.
Then go in Google map settings in the app and turn on wifi only. When that is set it will say "when not connected to wifi only offline maps will work"
Also while in settings go to "offline map settings"
Ensure download preferences is set to wifi only.
11-25-2020 08:23 PM
Turning off VPN didn't actually work. I had to DELETE VPN!
11-25-2020 08:22 PM
Turn off VPN
11-25-2020 08:22 PM
Tried switching to 3G. Samesies. Thank you for the idea. Was worth a shot!
11-25-2020 08:18 PM
Yes, maps is switched on below cellular. Yes, maps works fine on wifi. I will try.
11-25-2020 08:13 PM
I assume you mean "maps is on cellular" means is switched on ON below the cellular switch?Does Google Maps work on wifi?
Have you done the last iOS update? Is your cellular on LTE or 3G. What ever it is...try the other.
11-25-2020 08:13 PM
Create a moderator support ticket for help using the Chat button at the bottom right corner of this page.
