sim pin
hang_on
hi, i need to enter the pin to lock my sim card. i enter the 4 digits i choose in the activation form. it was not that. where to find it. thanks for your help
2 REPLIES 2
I recommend not using the SIM PIN for security. Just stick to maybe fingerprint or drawing a shape. The SIM PIN is rarely used then you end up forgetting it and get locked out.
Jb456
@hang_on
PM default sim pin should be 1234
