08-27-2019 06:30 PM - edited 01-05-2022 06:41 AM
new iPhone Xr . message says SIM not Supported. Phone is unlocked.
Got a new SIM card. still getting same message.
08-27-2019 07:36 PM
I would go to the store where you brought the phone to be sure thet sold you an unlocked one.
08-27-2019 07:28 PM
Try the compability test. That should help.
08-27-2019 06:35 PM - edited 08-27-2019 06:35 PM
08-27-2019 06:34 PM
Try connecting your phone to a computer with your sim card in the phone. Sometimes, when switching sim cards (if you had a different carrier's sim card in there before), it is necessary to activate the device while connecting to the Apple server. I know iTunes is the old-fashioned way of activation but it is stil a method that should work.
08-27-2019 06:34 PM
phone is 100% unlocked, bought it outright new
08-27-2019 06:33 PM
thanks, robert. SIM was working on other phone. got new SIM, registed it, now neither SIM works in either phone
08-27-2019 06:32 PM - edited 08-27-2019 06:38 PM
@ottilienSIM not supported means the iPhone is not unlocked.. but have you connected the phone to a wifi network, the iPhone needs to look up your activation status from the Apple server.
08-27-2019 06:32 PM - edited 08-27-2019 06:33 PM
@ottilien wrote:new iPhone Xr . message says SIM not Supported. Phone is unlocked.
@ottilien Are you absolutly sure its unlocked? Sometimes we think our phone is unlocked, but its actually locked. Try sim in another unlocked phone. that will isolate a sim issue vs a hardware issue.
