sim card
03-29-2019 04:08 PM - edited 01-05-2022 04:02 AM
I purchased a PB sim card last week at Walmart to set up account for my grandaughter,when i tried to register it keeps saying invalid sim.Help.
Thanks
Jim
Joining Public
03-30-2019 10:24 PM
I had this problem too, but purchased my SIM from the Mobile Shop.
I ended up contacting the location where I bought the SIM, explained my situation, and they were willing to exhange the SIM without much hassle.
Hope that helps, good luck.
03-29-2019 08:51 PM
Close all the browser windows where you were working on activating your account and you have to wait for 50 mins before you can resume the process again.
I just went through this issue like 40 mins ago.
03-29-2019 07:21 PM
@jimbodom wrote:I purchased a PB sim card last week at Walmart to set up account for my grandaughter,when i tried to register it keeps saying invalid sim.Help.
Thanks
Jim
Try inserting the SIM into your phone, power it up and check in case your SIM is already activiated and connect to Public Mobile network. If not, you can try SIM activation again in a new Incognito window using Chrome.
03-29-2019 04:28 PM
yes
thanks
jim
03-29-2019 04:27 PM
tried,no account
thanks
jim
03-29-2019 04:23 PM
Thanks
Jim
Wait an hour or two, clear browser cache and then try again.
Did you ever enter payment info? If you did, check to see if you were charged.
If activation failed part way, moderators can fix that.
If Walmart sold a sim by mistake that they already activated, you will need new sim card.
03-29-2019 04:18 PM
@jimbodom I think there's a chance the activation was successful, but now that you're re-submitting the activation form the sim is coming up invalid (because it's already activated).
Can you try logging in? Click on "My Account" in the top right, then enter the email and password you created during activation and see if you're able to log in. If so, you're already activated. If not, contact the mods as @lukealex121 suggested.
Good luck!
03-29-2019 04:17 PM
Thanks
Jim
Hi @jimbodom, welcome to Public Mobile.
You bought the SIM card from Wal-mart and they did not activate it in store, is that right?
When you're going through the activation process online, you're getting the 'invalid SIM' message when entering it - so, before you get to the payment step?
03-29-2019 04:17 PM
yes the number is entered correctly.
thanks
Jim
03-29-2019 04:11 PM
If you are positive that you have entered the SIM number correctly, and it still does not work, you may have to send a Private Message to the @CS_Agent, who could help you with this issue. Ensure you include the number from the SIM card you purchased.
