03-21-2019 10:46 AM - edited 01-05-2022 03:51 AM
I transfer from rogers to public,set up at one superstore yesterday afternoon,but almost 18hours the card still not activited?
03-21-2019 11:17 AM
@Jackyang1 wrote:thanks
No problem
. Hopefully you get a quick response back from the @CS_Agent and resolve your issue.
All the best.
03-21-2019 11:08 AM
thanks
03-21-2019 10:57 AM - edited 03-21-2019 11:36 AM
@Jackyang1 wrote:cannot make call
That's not good because you should be able to make calls. Are you sure the rep entered the correct number? Anyway you need to to get a moderator to help you resolve this.
You should send a message to the @CS_Agent to take a look at it. Click here:
The link sends you to the private message function and adds the moderator team as recipient for a private message. You just have to enter a title and text in the body of the message and post. The message will be received by the moderator team and they will respond to it. You will receive the response in your private message inbox.
03-21-2019 10:54 AM
cannot make call
03-21-2019 10:47 AM
@Jackyang1 wrote:I transfer from rogers to public,set up at one superstore yesterday afternoon,but almost 18hours the card still not activited?
Can you make calls on your phone?
