problem sim
bahram
Hi there, i have sim number xxxxxxxxxxx public mobile it show invalid even few days ago i did active and i transfer my number from fido 15 days ago and i have more then month balance so what i should to do ?
7 REPLIES 7
srlawren
@bahram wrote:
i have actived my public mobil sim but it doesn,t work and i switch off from fido and transfer my number from fido to public mobile the nuber 514-XXX-XXXX until to now i didn,t get and i paid money for hole month money 28.75 and my conection public mobil doesn,t work .so refund my money and cancel  request to fido for my number.thanks
Hi @bahram, I'm not sure where to start here.  You're saying you've gone for 2 months without service???  Okay first of all if you successfully transferred your number from Fido, I don't believe there's any way to cancel the request to fido--it's likely your Fido account has been closed for some time, ever since the port completed.
There are a few things that could be wrong.  #1 your phone may be incompatible (not all phones that work with Fido (or Rogers/Chatr) work with Public Mobile.  Rogers operates a 2G GSM network and is the only Canadian provider to do so.  So, if you are using a phone from overseas or one that is very old, it's quite possible it does not have the necessary 3G frequencies.  I've talked more about that in this response on your other thread just a moment ago.  It's also possible that if you bought the phone from Fido, it may well be completely compatible but may be locked to Fido.  If that's the case, you will need to contact Fido to unlock it for you before you can use it.
If both of those things are not the cause, you may have a encountered an activation glitch.  I told you A MONTH AND A HALF AGO, in this very same thread, how exactly you can get help for that.  Have you contacted the moderator team by private message?  If not, please scroll up a few messages in this thread, or click here for the details.
Let me re-iterate this one more time:  if you need help with your account, the only way to do so is by private messaging the moderator team.  Please do so.
bahram
Hi there , my sim card is doesn,t work from the beganing also i paid twice the monthly payment the sim card number89122300xxxxxxxx .i want transfer my charter from charter mobil number to public the number 514-xxxxxxxx and give my two months credit .
my name ;bahram khan
bahram
srlawren
Look, @bahram, I told you ON MONDAY how to fix this.  Have you contacted the moderator team yet?  Please, they are the ONLY ones that can help you with this issue.
To be completely honest, I have no idea what your issue is because you've been all over the map across a few different threads [one, two, three, plus the current thread] and very difficult to understand, but contacting the moderators is your next step.  Please, trust me here.  Click the link above, where I gave you all the info you need to do this.  It's not difficult, you just have to get the ball rolling and they will assist.
Someone_here
Not sure what's your exact problem, but if you already activated your SIM, then it is normal to receive the "Invalid SIM" message if you try to write your SIM card number anywhere in the system again (reactivating a new line or changing SIM in the selfserve)...
LEGO
@bahram Please, remove your SIM card number for confidentiality, as this is a public forum.
You will need to send a private message to a Moderator_Team, they will help you!
Here is the link: click here
In your message, please provide your name, account number and PIN.
Good luck!
Contact Support hours of operation:
Monday - Friday 9AM (EDT) - 9PM (EDT) Saturday - Sunday 9AM (EDT) - 7:30PM (EDT)
bahram
