09-10-2020 07:26 PM - edited 01-05-2022 01:09 PM
Typed my usual password, a couple of times, wait several hours, tried again, not working.
Tried ''forgot my password'', but completely forgot that there was a security question, have my phone since 2014...
What can I do? Thanks
My Account
11-20-2020 06:15 PM
You have to create a new account with all the same info...Voila!! Worked for me
09-10-2020 07:35 PM - edited 09-10-2020 07:37 PM
Hi @PierreK ,
Well, it seems like you did what is usually suggested, waited for a bit and tried again. Tried the "forgot your password" route, didn't work.
Guess you really locked yourself out!
Moderators can get you fixed up again. 🙂
To contact the Moderator_Team, there are two ways to reach them:
1-Click the question mark on the bottom right hand side of your screen to talk to SIMon the chat bot.
https://publicmobile.ca.ada.support/chat/
OR
2-Contact the Moderator_Team via private message using this link.
09-10-2020 07:35 PM
@PierreK wrote:Typed my usual password, a couple of times, wait several hours, tried again, not working.
@PierreK hello if none of that works try contacting a moderator you can do so by clicking the question mark at the lower right corner,to avoid going around in circles with Simon say that you want a human to speak to, a ticket will then be generated briefly mention your issue , you should get a response between 2 to 48 hours a reply should show up in your little envelope in the top right corner
09-10-2020 07:28 PM
@PierreK contact a moderator click on the ? Bottom right hand corner Ask Simon to speak to a human this will help create a ticket to speak to a moderator mention password reset check the envelope top right corner for a reply response time is 2 to 48 hours
