02-21-2020 01:17 PM - edited 01-05-2022 09:36 AM
hi i ported my number from previous telecom, igot ported but i am not able to recived call just able to do outgoing call, please help
Joining Public
02-21-2020 03:30 PM
@Bhagwan55555 If you ported a a cell number, it should be done in 3 hours. If it's been more than that, contact a moderator as mentioned above. If it's a landline it takes up to 2.5 days.
02-21-2020 02:08 PM
FYI
Number porting is a 2 stage process:
Stage 1. After submitted your porting request, PM set up your old number on your PM account. Login to your account. Select the [Plan and Add-Ons] tab. Is your old number showing on the [Plan and Add-Ons] display?
If yes, PM has done its work to setup your old number for you to call out, send text and data.
If no, you should create a support ticket for moderator to investigate.
Stage 2. Now, you are waiting for your old provider to release you number to PM. Not until your old provider release your number, all the incoming calls and texts will continue to go to your old provider. If your old SIM card is still working, continue to use it until is stops working. Then, start using PM SIM Card.
Welcome to PM.
02-21-2020 01:20 PM
It might take a couple days for the calls to start coming to your phone. When I ported my number, I was receiving texts and could call out right away, but the calls were still going to my other phone for a couple days. After the porting process was completed it was all normal with calls going to my new phone.
Did you port from another cell phone or land line?
02-21-2020 01:20 PM
@Bhagwan55555 wrote:hi i ported my number from previous telecom, igot ported but i am not able to recived call just able to do outgoing call, please help
It sounds like you have a stuck port and will need the assistance of the Moderators. In the mean time you should be able to use your old sim still and be able to receive calls (hopefully it hasn't disconnected) To reach the moderators you need to click on the "?" at the bottom right hand of the screen and follow the prompts through SIMon to help submit a trouble ticket
02-21-2020 01:20 PM
Porting is a 2 step process. It can take up to a few hours for the second step to complete.
In the meantime, you can continue to use your old provider's sim. Which carrier are you porting from?
