phone not working
seig
I get message that I dont have long distance add on so I upgraded for $15 to $25 and still the phone does not work. What am I doing wrong, very frustrated, been a few days now
gpixel
@seig hi what is the area code you are trying to call?
iliketotalk
@seig hi try the tips already suggested if it doesn't work  try contacting a moderator you can do so by clicking the question mark at the lower right corner,to avoid going around in circles with Simon say that you want a human to speak to, a ticket will then be generated briefly mention your issue, you should get a response between 2 to 48 hours a reply should show up in your little envelope in the top right corner
gblackma
@seig are you on the $10 50/50 plan? Log into your self service account. And chexk to see if th have minutes. If you do, try dialing the number with a1 in front of it. If you dont, buy the 500 minute $5 addon. It's a 2 step process do a one time payment and add the $5 funds and then buy it. Here's where and how to do it. Stay safe.
shep22
@seig
@seig hi do a network reset restart your phone try dialing 1 in front of your number
