payment day
11-10-2020 10:14 AM - edited 01-05-2022 05:25 PM
11-15-2020 04:14 PM
@Copierwiz wrote:If you say payment is for 30 day cycle then how come it started after a year with them, all months from last oct-nov it was on 22nd each month so question is why now.
Do this.....and show us "your" screen shot results.
Do a calendar entry on your phone or tablet. Enter the exact date the last time you paid. Then have the calendar entry repeat every 30 days.
Ie. Copierwiz Public Mobile Due.
Then search the calendar for "Copierwiz Public Mobile Due" and then do a screen shot of it.
You will then know exactly what dates your next payments are due.
11-15-2020 04:00 PM - edited 11-15-2020 04:01 PM
@Copierwiz It's not possible to have had the same day for the past year. Go into your self serve, select payment history, select 6 months, then click transaction type at the top of the main window. This sorts them. If you look at mine for the past 5 the dates are not all the same. Post a pic of yours please.
11-15-2020 03:52 PM
11-14-2020 05:06 PM
thank you!
11-14-2020 05:04 PM
thank you
11-12-2020 01:41 PM
@Kind333 wrote:Hi,
My payment day is always one day before last month, don't know why?
Ie. Kind333 Public Mobile Due.
Then search the calendar for "Kind333 Public Mobile Due" and then do a screen shot of it.
11-12-2020 12:49 PM
It will change depending on the month as your plan is on a 30 day cycle. For the months with 30 days, it will be on the same day the next month. For the months with 31 days, it will be one day before the next month. For February it could be either 1 or 2 days before in March, depending on whether it's a leap year.
11-10-2020 06:24 PM - edited 11-10-2020 06:27 PM
As mentioned by the others, the plans that Public Mobile offer are for every 30 day cycle as opposed to every month. Since the amount of days in each month vary (28, 29, 30, or 31 days), it would make sense for your payment date to change every so often.
11-10-2020 11:28 AM
@Kind333 Because PM uses 30 day cycle, not a month.
11-10-2020 10:16 AM
@Kind333 wrote:Hi,
This is not a monthly service. It's 30 days.
It will take about 5 years to inch up and then back around to when you first started.
