old number back pls
03-23-2019 09:23 PM - edited 01-05-2022 03:54 AM
03-24-2019 12:30 AM - edited 03-24-2019 12:31 AM
@jkimshsy wrote:i am $30plan member
If your Koodo account is still active you just need to login to your account and get your account number.
If you were on a Koodo postpaid plan then login into your PM account by clicking on the "My account" button top right and select change number and setup the port.
If you are a prepaid Koodo customer then click on the mailbox icon and send a message to @CS_Agent include your Koodo account information, phone number and name and they will move your number (port) from Kood.
03-24-2019 12:24 AM
i am $30plan member
03-24-2019 12:12 AM
@jkimshsy wrote:Yes Koodo account stil active
But. Is. It. Prepaid. Or. Not?
We're just trying to help point you in the right direction.
03-24-2019 12:11 AM
If that is a prepaid Koodo account, you must tell Moderator_Team to port in your number. You cannot do it from your self-serve account.
03-24-2019 12:07 AM
03-23-2019 11:58 PM
@jkimshsy, is your Koodo account still active? It must be active in order for you to be able to transfer the number. If it is active, you can initiate a number transfer from within your self serve portal. Just go to Plan and Add-Ons, then Change Phone number. If it is a Koodo prepaid number, you must ask moderators for help.
Click here to send the moderator team a private message. Their hours are: Mon-Fri 8AM-Midnight(EST) & Sat/Sun 8AM-10:00PM(EST)
03-23-2019 11:58 PM - edited 03-24-2019 12:02 AM
@jkimshsy wrote:i switched to public mobile from koodo and i had to choose new phone number. After then, i tried to get back my old number many many times. But didn't work.Pls help me
Posting again in another topic will not help you any better to retrieve your number. Follow what has been said above or provide more details on your old phone number you are trying to port.
03-23-2019 11:57 PM
Is it Koodo prepaid or postpaid? Is your Koodo account stil active?
03-23-2019 11:54 PM
03-23-2019 11:34 PM
i had $30 plan member. and i would like to use change number function to get my old number Please help me.
03-23-2019 11:21 PM
Were you on Koodo prepaid or postpaid? Prepaid requires moderator intervention.
What do you "get back"? Are you trying to use the Change number/Transfer number function?
03-23-2019 11:17 PM
03-23-2019 09:41 PM
@jkimshsy , if you ported your Public Mobile number to another carrier, that number resides with the new carrier. There is nothing that Public Mobile can do to get your number back. You would need to activate a new account with Public Mobile and then submit a number port back in.
03-23-2019 09:28 PM
@jkimshsy wrote:I accidentally ported in a wrong phone number, and want my old public mobile number back. Pls Help me.
Ok, you do realize whatever you ported over that account will be cancelled once the port completes?
Is the wrong number you entered yours?
The best thing to do is to send a private message to @CS_Agent with the details and they should be able to givbe you advice on how to proceed.
