no data usage shown on usage history
4siu
Under the usage history tab, it only shows talk time minutes usage but no daily data usage. I can only see the total data used and remaing MB. I can see the daily usage before but now it does not shown anymore, Why???
8 REPLIES 8
Another odd bug
After the return of data to use history my data use is WAY UP
I strongly suspect there was a system bug before they working on
I have used more data in past week than in past month, without changing my use patterns
The columns in history are also all changed (at least twice) so something has happened on Publics side
@Mary_M can we get some feedback on this issue?
I am strongly suspecting the data was not counting properly since after all our use history dissapeard it shows alot more total use under overview page
kav2001c
@4siu just for curiosity sake
My online tracker shows data from April 25th and prior
No data showed between 26 & today
If you go back when was last day it shows your use?
kav2001c
Yup I was just about to start the same thread
According to my online account I last used data on April 25th
@Mary_M is this a bug or?
@4siu  If you have an iphone you'll know the data management sucks.
I use an app called my data manager and its great.  It has customer settings and reminders very useful.
@cameron94x
Agreed I m been using my data management as well its shows the usage right on notification page also on android you have a main screen widget as well
** I am not a Mod, please do not include any private info in a private message to me.**
honestly, i would install a usage tracker. It could be easier than logging into self serve and checking that.
Both iOS and android have them by default, but androids is much better, as you can actually turn data off or at least stop it from working, when you reach a certian limit. You can also download data mangement apps for both devices. You can set them for a certian length too (but i keep mine around 4gb a month limit).
Samianauman
It's showing mine but its more like a system glitch try a different browser and if still doesn't show up send a msg to mod since they have access to your account they can manually fix it for you
Contact mod dept they will help you with the process
In your private message to any moderator include whatever bits of the following info you have:
* PM account email address
* PM phone number
* Detailed explanation
* Community Moderators are available from Mon-Thursday 9am(EST) to 9pm(EST) and Friday, Saturday, and Sunday from 9am(EST) to 5:30pm(EST)
Here is the link for how to contact moderators http://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Updiated-Contacting-our-Community-Moder...
Just rechecked mine yep you are right its only showing call and text I think it's a website error I. M tagging mod they can look into it @Shazia_K
