12-21-2019 11:05 PM - edited 01-05-2022 08:39 AM
My phone work fine, but can not access internet using cell data. There is no any change on my phone and used to be working fine. It happened since couple of days ago. Appreciated if anybody could help.
Roy
12-25-2019 05:43 PM
For troubleshooting the no internet problem check your devices "access point names" setting .
Found here :
Note: The location of these setting may vary depending on which version of Android you are using. Generally Access Point Names (APN) settings are under Settings > Connections (or Network & Internet) > Mobile Network > Advanced. After you go to “ Access Point Names ”, Press ADD to add new APN.
It should read like this
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Username: Leave blank
Password: Leave blank
Server: Leave blank
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
APN type: Leave blank
12-23-2019 09:13 PM
@Ivasofya wrote:Usually it cuts off like that when you've used up all your data. I am assuming you tried the basic thing like set phone to airplane mode for a minute and turn the cellular back on, restart your phone etc. someimes my phones need s a bit of a boost like that when data stops working.
This issue was solved a couple days ago. In this case, it apeears to have been an APN setting issue.
12-23-2019 09:04 AM
12-22-2019 01:56 PM
Do you see the connected name at the top of your phone?
If connected, there are some bars show how good the signal is, this is the starting point.
If you dont even see this, then you are not connected.
You need to go to setting - network - manual connect.
It varies depends on what phone you use.
12-22-2019 12:14 AM
Phones can sometimes "forget" APN Settings (and/or other things) for no apparent reason. Often because software did some sort of sneaky update without any prompting. Sometimes because an NVRAM block was corrupted in hardware (don't be alarmed, it happens to most devices over time so they're engineered to self-recover whatever data can be saved).
So sometimes you've just gotta reset (or even factory reset) the thing and manually (re)input your APN Settings, lol. It's only a real problem if it keeps recurring.
12-22-2019 12:09 AM
Network comes back now, APN looks good though, just reset "PC Mobile". Thanks a lot for your help.
12-21-2019 11:50 PM
@RoySun wrote:android
@RoySun Make sure data is turned on and you have the correct APN setting. This is the Public Mobile APN setting that you will need:
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Server: Leave blank
MMS port: 80
MCC: 302
MNC: 220
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: GID
Don't forget to save these settings and then select this APN as the active one.
12-21-2019 11:43 PM - edited 12-21-2019 11:44 PM
Pull down quick lauch and check if data toggle is off. That can be done accidently very easily.
12-21-2019 11:43 PM
@cavemantoronto might be on to something...check your APN settings.
12-21-2019 11:41 PM
android
12-21-2019 11:36 PM
12-21-2019 11:36 PM
@RoySun Or add the free holiday 1gb data add on from public mobile if you haven't done so already.
12-21-2019 11:35 PM
I checked my acocunt. There are a lot of remaining data with my plan. I don't see problem with my account just not able to access network with cell data. I am able to call and message. Wired.
12-21-2019 11:32 PM
@geopublic wrote:@RoySun If it just stopped working out means that you have used up all your data. You need to wait for your plan renewal, buy an add-on or change plans for our to start working again.
Another option is contact mods and ask them to renew the same plan early.
12-21-2019 11:30 PM - edited 12-21-2019 11:32 PM
@RoySun If it just stopped working it means that you have used up all your data. You need to wait for your plan renewal, buy an add-on or change plans for our to start working again.
12-21-2019 11:22 PM
@CannonFodder wrote:Can we assume you've done the obvious things already, i.e. checked to make sure data is still turned on in the settings, and/or whether or not you ran out of data on your plan?
If so, is there any chance we're talking about you trying to access data from various places..... am thinking that MAYBE you're currently in an area of spotty service, like I'm currently in?
Also chance of accidental APN setting change.
12-21-2019 11:12 PM
12-21-2019 11:09 PM
@RoySun wrote:My phone work fine, but can not access internet using cell data. There is no any change on my phone and used to be working fine. It happened since couple of days ago. Appreciated if anybody could help.
Roy
Go into account to find how much data is remaining. Nothing shown means all has been used.
12-21-2019 11:09 PM - edited 04-05-2020 02:01 AM
Stay Safe!
