moto g5 plus - international version
10-10-2017 07:01 PM - edited 01-04-2022 02:44 PM
so i bought a refurbished moto g5 plus.... and sometimes it doesnt work properly and its still under warranty...so i am returning it however its not the international version..
does anybody have the international version? i found a good deal on one.. does it work with public mobile? internet sites dont seem to say for sure one way or the other..
Phones
10-10-2017 07:45 PM
Hi,
Do you have the model number for the international version of the Moto G5 Plus? I know that Lenovo uses the same name for different versions of the phone. With a specific model number, you will be able to compare the results from different websites including willmyphonework.net.
Thanks.
10-10-2017 07:44 PM
@TML2016 by international version, I'm assuming you mean either the single SIM XT1684 or the dual SIM XT1685, rather than the USA model (XT1687). If so, both versions are fine for calls, texts, and 3G HSPA+ data, since they have the 850MHz & 1900MHz 3G bands required for those things. On the faster data side, you'd be missing band 4, the primary LTE band in use with PM, as well as some supplementary bands such as band 2, 5, 12, 17. You've only got band 7. So depending where you are located, you may get some band 7, but if it's not availabile, you'll drop back down to 3G HSPA+. This may be find for your needs though--honestly it's fast enough for most people.
10-10-2017 07:28 PM
Check the compatibility on the site: https://willmyphonework.net/
This site is know to be accurate.
