missing rewards
dreamboats198
Hi, I need to check where my rewards points are being used for. I should have got more than what I see in my balance. How do I go about this request?
10 REPLIES 10
mynewhome
You can see a summary in "MY ACCOUNT" (upper right hand corner) "Overview"
joedf
Yeah I want to ask something about this too...
My Rewards
Loyalty Reward $0
AutoPay Reward ($2)
Community Reward $0
Refer-a-Friend Reward ($1)
My rewards didn't apply for April....
In the payment history, all I see is this "Apr 8, 2019 System issue/ Problème du système" and no Auto-pay or Referral bonus was applied, but it says it for previous months... I got charged extra on my credit card compared to my usual balance even tho the plan wasn't changed...
@dreamboats198 wrote:
Thanks for your reply. There were some rewards earned at the time of enrollment and auto pay which I don't see now. Is there a number to speak to someone about this?
Public Mobile does not have a phone number for customers to call.  All contact is done by sending Moderator_Team a private message.  https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
No there is no number to speak to someone..but here with the moderator acn help you with that..https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437 give them details of your questions. Waiting time is few hours to 2 days.
dreamboats198
There were some rewards I got for enrollment and auto pay . how do I speak to someone about this
dreamboats198
Jackhyf63
@dreamboats198 I hope you got your missing rewards.
Pizzaeh
Hi @dreamboats198 , there are four different rewards (listed below), which one are you referring to?  When you log into your self-serve account, what amounts are you seeing?
Loyalty
Autopay
Community
Refer-a-Friend
NDesai
@dreamboats198  What rewards are you specifically not seeing? To see the details, go to My Rewards page. If you want to see how they are being used, go to Payment History and that will show you how it is added to your available balance before renewing your plan.
ShawnC13
What rewards are you talking about?  Community rewards or referral credits?  Referral credits will show up in available funds and not rewards.
