12-22-2017 10:38 AM - edited 01-05-2022 03:47 AM
i tried to port my PM number to bell on sunday and the port has not gone through as of yet. Bell has told me that the number is inactive and thet are not able to activate it as it is not there number. When they had tried to port the number over it cancelled my phone services right away and i have not been able to access my PM account nor i have not been able to use my phone. i need some help
12-24-2017 04:41 PM
Hope it get sorted out before the holiday hits!
12-23-2017 09:46 AM
12-22-2017 04:34 PM
Ouch.
12-22-2017 12:45 PM
@will13am @ShawnC13 thank you for your help. I have contacted the moderator team now I have to see if that can do that.
They replied saying it's a bell issue and to contact the bell porting department to fix it. I have and bell can't port over BC the number in inactive. So hopefully they can reactivate my account with my number so they can transfer over
12-22-2017 11:13 AM
@Smattina93, as suggested, contact the moderator team. Ask them to switch your plan to the cheapest available (text only, 30 days) to facilitate the port. Since there are no refunds, you don't want to buy an expensive plan. Customers cannot perform plan changes when the account is not active.
12-22-2017 10:49 AM
@Smattina93, was your plan active when you tried the port?
