iPhone 7
sselvadurai
Is the iPhone 7 compatible with the public mobile network?
mylabmax
Yup. Iphone 7 is compatible.  Using 1 right now.
Ionut
This is the best website to check your phone. Just introduce there the dates and it will show you If works and what kind of data you got. (3G/4G/LTE based on phone model)
http://willmyphonework.net/
Note: Iphone it's listed as Apple into the website not as Iphone*
sselvadurai
@PhoneSeeker sounds good, thank you for your help 🙂
PhoneSeeker
Yes it is 🙂 Just make sure it is unlocked first. If it is locked (purchased from Roger/Fido/Bell etc.) you will need to contact your provider and purchase an unlock code (usually around $50). When you put in a Public Mobile SIM, you will be asked to put in the code that you purchased from your previous provider.
Telus/Koodo iPhones should be compatible with Public Mobile without unlocking. If you have a Koodo/Telus iPhone, try your Public Mobile SIM. If it doesn't ask for an unlock code than you should be good to go! 🙂
