iPhone 17e
keithmac
New iPhone 17e, public mobile app not showing me eSIM compatibility
2 REPLIES 2
slusagm
it is compatible, but some users have trouble with iPhone eSIM occasionally.  Ask PM to help and check
Simply open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA  code when login, use email to receive code instead of SMS if you cannot receive the text on the phone.)    When open Chatbot ticket, Type the question Submit ticket and select Contact Us to get to ticket open screen
But if you have trouble using Chatbot to open ticket, then message PM using this link:
PM will reply to your community inbox,  between 9AM-10PM EST (Mon-Sun), check here:
