05-08-2018 03:05 PM - edited 01-05-2022 04:44 AM
05-09-2018 09:08 AM
To change your plan.Log in to your account beside where it says account status active you should see change plan. Click on it to build your plan (be cautious that all the features you want are part of the package build). It is easiest to have it chang on the date of your next renewal pay .If you want to change right now first add any additional money to your account if increasing plan then select change plan.
If you have received a satisfactory solution to you inquiry please indicate so the post can be finalized. If you require further information on this specific topic please continue to post as there are lots of helpful people in the pm community
05-08-2018 05:11 PM
You can do it through Self Serve by clicking this button:
After you choose your new plan, you would have to decide, if you want to apply changes immediately or at your next renewal date.
05-08-2018 05:00 PM
thanks you
05-08-2018 04:13 PM
@Nickgazoo, just to be certain, you want to change to a plan with different features than the current one. Is your intention simply to renew your current plan? In either case, you can perform this function in your online account. If you need assistance, the moderator team will be able to assist with managing this and other online features. The moderator team can be reached via private message using this link. Refer to the following knowledge base link for information on contacting the moderator team.
05-08-2018 03:46 PM
Who is mods
05-08-2018 03:23 PM
To change your plan.. Log in to your account .Beside account status active just click on change plan. Choose your plan you want and then have it changed on the day your plan comes out on auto pay .If you want to change right now first add money to your account ,then go to change plan and have it changed today. hope this helps you.
05-08-2018 03:22 PM
If your plan is for xpired you need to ask mods to make the change.
If your plan is active you can future date a plan change or you can make an immediate plan change log into self serve and click change can button. If you do an immediate plan change you will forefit any time remaining on you old plan
05-08-2018 02:57 PM
