how build the plan
Gurpreet123
12 REPLIES 12
I can use Google Translate. State your problem in your first language, using proper grammar, and I will use Google Translate to communicate with you.
In English, state the first language that your post will be in so that I can use Google Translate properly.
Hello,
This is as much as I understand from your post.
1: You have a Public Mobile number
2: You plan to buy a $20 voucher
3: You have a concern about the voucher being used
Beyond the above, I do not understand what assistance that you are seeking. 😞
Hi,
I accept your apology, and wish to help you.
In this case, and I say this with respect, I cannot understand what your other post means.
Gurpreet123
Hi,
You post every day. As Cyber said, it is robotic.
Gurpreet123
DK
I thought you cancelled your plan?
chukdefatey
^Simple Solution is to Stop feeding the Troll
@Gurpreet123,
Are you kidding us ?
You are posting everyday like a robot.
Gurpreet123
Cyber
@Gurpreet123,
You can build your custom plan at http://publicmobile.ca/en/on/plans
For new customers, please note that Public Mobile is currently in BETA.
They are temporarily accepting new customers only by invitation.
To join the BETA phase, you must register here : http://publicmobile.ca/en/on/beta
You will be contacted by email within a few weeks. Once you receive your invitation code, you will be able to subscribe on Public Mobile and order a free of charge SIM card.
For now, there is no faster way to subscribe on Public Mobile. They are in BETA to make sure everything works perfectly before the official launch.
Martin
Legend
Legend
Hello,
Follow the instructions on the page.
