05-16-2024
12:00 AM
05-16-2024
08:27 AM
computergeek541
i'm thinking of getting the nokia 2780 but i want to make sure public mobile is compatible with it first. i saw some people say yes but these replies were a bit dated and i don't want to end up with a phone i can't use. anyone knows? thanks!
03-02-2026 11:56 PM
I got a 2780 and it works for calls and sms, but not mms. So, sending/receiving things like pictures or being in group chats isn't possible
09-14-2025 11:21 AM
Did you end up purchasing a Nokia 2780 and does it work with Public Mobile?.. I too am interested in doing this.
05-16-2024 08:29 AM
05-16-2024 01:28 AM
You can have a family or friend download the PM app to activate the SIM.
Once your SIM is activated, you can manage your account online then delete the app from your family/friend’s phone.
05-16-2024 01:17 AM
Should be OK. Public mobile is using telus network, which is compatible with nokia 2780 based on following websites.
https://www.gsmarena.com/nokia_2780_flip-11973.php
05-16-2024 12:37 AM
@ka03 you need to download the public mobile app inorder to purchase a plan. Can this phone download apps?
You can check if it's on the whitelist here.
