09-29-2021 11:34 AM - edited 01-06-2022 03:27 AM
09-29-2021 07:49 PM
@esjliv : I see I'm in here. I guess he got something figured out and came back to say "fixed". Ok. Thanks for the useless update.
Sometimes I do wonder if I should quote the post. But then sometimes I wonder if people don't read the whole post by clicking See more. It's a quandary.
09-29-2021 06:43 PM - edited 09-29-2021 06:44 PM
@Subotai79 wrote:fixed
Question: Fixed
Solution: Fixed
That is baffling. 🤔
Did a Reboot fix you up here? Surprisingly, this is a fix for many-an-issue.
09-29-2021 11:43 AM
@Subotai79 : What happens when you dial 611? Can you login to your self-serve account? Does the status show as active?
