fast busy
12-05-2020 12:07 PM - edited 01-05-2022 04:23 PM
12-05-2020 01:56 PM
Good Info....
12-05-2020 12:25 PM
@royaladd Some possibilities here: https://www.techwalla.com/articles/what-does-a-fast-busy-signal-mean-on-a-cell-phone
12-05-2020 12:12 PM
Is this just one person or anyone who calls you?
Did you just port a phone number?
FYI - If you just ported your phone number from another cell provider it could take a few hours to complete the port. Using the other cell provider's SIM you should be still receiving calls on it, until the port completes.
If you ported from a landline it could take up to 7 days to complete.
Make sure you do not cancel your previous provider's services until the port is complete.
12-05-2020 12:09 PM
A fast busy is often the result of a network capacity issue. Which carrier is the other person calling you from?
