eSIM not working after number transfer
Lois99
I received confirmation that my number transfer was completed. The PM app shows the transfer as successful, but my phone is stuck on SOS” with no signal.
2 REPLIES 2
oshow1
I had the same issue. I just shut off my phone and took the SIM card out. Turned it back on and it’s working now
slusagm
removed the old sim card or disable old esim
Check if PM esim is enabled and set as Primary.  Reboot phone and Reset network settigns
if you need PM to help, open ticket.  Since you cannot properly login, you won't be able to open the preferred Chatbot ticket.  So, you will need to message them here:
