eSIM activation
Ro_Bi
Hi,
 i have not recieved the activation summary emails and also eSIM QR code.
In addition at the last stage "Step6 of 6: Activate": I get error "ESIM NOT INSTALLED" Something didn't go right while installing your eSIM. Click below and retry.
My phone is iphone 15 which support e-Sim.
7 REPLIES 7
@Ro_Bi wrote:
Hi @computergeek541
 i donot  have access to above link. I get as "Access Denied"
The link is just a placeholder to indicate that duplicate content had been removed.
Ro_Bi
Hi @computergeek541
Ro_Bi
@slusagm  thanks, some how after reboot of phone it is sending the verification code to the new number which i donot see as it is not activated on phone yet
slusagm
You can also try reboot phone and relogin the app, some have success with that
And also check Sim card Manager screen to see if a Public Mobile sim is already installed, sometimes it is..it is installed but not enabled and you need to manually turn it on
Ro_Bi
@RavingRaven  Thanks for the reply. I have raised a ticket to Cs_Agent as per the link sent.
RavingRaven
@Ro_Bi
This is a common issue with e-sim. You will probably need to activate with a physical sim card then decide whether to switch to e-sim. Contact customer support to check on your activation.
