deleting voicemail function
07-27-2019 12:00 PM - edited 01-05-2022 06:08 AM
How can I delete Voicemail Function with PM plans?
I would like the phone to keep ringing instead of allowing
the caller to leave messages. I never read messages.
I used to be able to request Chatr to delete the function.
Joining Public
08-04-2019 11:39 AM
Thx for the advise.
I also include in my greetings asking the caller NOT to leave a message
but to call back again. Hope it works.
07-27-2019 04:55 PM
@geopublic wrote:
@Anonymous wrote:
@pingkaic wrote:How can I delete Voicemail Function with PM plans?
There's no deleting it. You can use the Extended Absence feature where you can tell it not to take recordings. Leave a greeting that you don't take messages.
You can also use a fake call forwarding number. But that causes a nasty error sounding thing to the caller.
There's a method to extend the ringing to only 30 seconds. I don't think there's a way to let it keep ringing
What happens if you extend the rings to the maximum and then have it forward to your own number again? Will thst work?
So like you coulda tested it 🙂
I tried on A8, S7 default dialer and it doesn't let it set the number to itself. (unanswered selection anyway)
07-27-2019 04:28 PM
Could always forward it to an app like YouMail and have it download on the device or just block all voice mails calls via the app, I know YouMail has the ability.
07-27-2019 03:45 PM
07-27-2019 12:28 PM
thanks for the reply. Too bad that the voicemail function cannot be deleted.
PM should consider this options; especially some seniors could not answer
calls that fast and do not know how to read voicemails.
07-27-2019 12:04 PM
