data not working after plan renewal
williamcys
Hi @Shazia_K
I was previously using a 30 day plan , and I tried to renew my plan yesterday with the 10 day 1 GB data only plan.  After renewal, data is not working anymore but I still get reception from Public Mobile.  I tried putting in my SIM card in my friend's phone , and it did not work on his phone either. His Public Mobile SIM works in my phone so it is not an issue with data setting on my phone. Have tried restarting as well.
Since I am on a 10 day plan , please help to see if data was enabled on your end asap.
Thanks !
1 REPLY 1
neilselden
Hi,
This is intersting, and good move to check your SIM on another phone, and vice-versa.
@Shazia_K, can someone please have a look here?
Also, as I mentioned in an earlier reply, it's best to contact a moderator directly.  Follow the det...
Cheers,
Neil
