11-10-2016 12:00 PM - edited 01-04-2022 06:12 PM
Hi, I am thinking for getting the deal on PM. 90 days- 4 GB/month. Since I am only getting the Unlimited Province Wide, is the Data Coverage also province wide ONLY, or actually Nation-Wide ? If someone can kindly clarify this for me it will be awesome.
Service
11-10-2016 01:37 PM
Sweet
11-10-2016 01:02 PM
Yep providing your plan remains in good standing, it will grandfather after 90 days.
11-10-2016 12:40 PM
Great question.... Can we also confirm that this promo will be grandfathered and will continue after 90 days for those of us that are on it?
11-10-2016 12:16 PM
Thanks. Great help. Really appreciate the quick respond.
11-10-2016 12:12 PM
11-10-2016 12:12 PM
Thank you!
11-10-2016 12:11 PM
So .. regardless my VOICE plan is province wide or nation wide, the included plan data will always be nation-wide then ?
11-10-2016 12:10 PM
province wide is limited to voice only. Text and data works without issue throughout Canada. You will need a long distance addon for out of province calls.
11-10-2016 12:08 PM
Data coverage is nation-wide using the Telus network.
Anywhere you can get Telus coverage, you can get Public Mobile coverage.
11-10-2016 12:06 PM - edited 11-10-2016 12:07 PM
Great question, I was wondering the same thing as well. I would assume that the data would only be province wide as well. Not sure though.
