community password
missorange
is that possible to change community password?
@missorange wrote:
@mimmo I only see email setting, after I click my setting. no password setting found.
Click on the little avatar in the upper right. A drop down appears. Click on My settings. A page appears with two rows of menu items. The second row will have password as an item. Click on that and there you are.
missorange
mimmo
yes click on your aviar in the top right of teh screen select my settings there you will see password change option
