cellular network
05-03-2020 11:18 PM - edited 01-05-2022 10:38 AM
Hi,
I have iphone 11 and i have been using Public Mbile network on it since 4 months now. Recently i got a notification saying update failed cellular network cant work. When i tried to restore the phone now its not working and saying unable to activate.
I am not sure if it happened due to public mobile network or the SIM doesnt support the phone any longer.
Phones
05-04-2020 01:40 AM - edited 05-04-2020 02:03 AM
@Kp1003 remove the sim and turn on your phone. update your iPhone to the latest software.
05-04-2020 01:04 AM
My phone is off,there is no way I can check the settings.
05-04-2020 01:04 AM
its a new phone and i recently got it from Apple store itself. the sim was working until Sunday 3 may, and now all of a sudden I got this notification.
05-04-2020 12:55 AM - edited 05-04-2020 01:10 AM
@Kp1003 Did you purchase that phone new or used? If used, it's possible that the phone has been blacklisted. To confirm test the sim in another phone. If it works, then your phone has been blacklisted for sure.
05-04-2020 12:54 AM
tried that and its not working. I even tried to put it in a recovery mode . Nothing is working as such.
05-04-2020 12:24 AM
sometimes trying to get the sim card out your iphone and resetting it does the trick apart from the suggestions above.
Ive experienced the same before and did what I suggested.
05-04-2020 12:15 AM
@Kp1003 I would try to use the same SIM in another phone to see whether or not the problem is with a card rather than with the device. Could you do that? Let us know so we could assist further. Thanks.
05-03-2020 11:29 PM - edited 05-03-2020 11:54 PM
@Kp1003 try resetting your network settings
1. From the home screen navigate to Settings>General>Reset
2. Tap Reset Network Settings
If prompted enter your passcode
3. Tap Reset Network Settings
4. Restart your phone
a software update from Apple could've caused this issue. you can also try seeing if there are any carrier updates
go to Settings-> General-> About
05-03-2020 11:21 PM - edited 05-03-2020 11:21 PM
@Kp1003 wrote:Hi,
If you go to devicecheck.ca, what's the status of your IMEI? If possible, try your sim card into another known working phone that is compatible with Public Mobile.
