04-23-2024
11:09 PM
04-23-2024
11:48 PM
computergeek541
Hi I purchased a subscription but never activated my sim card nor got a number. I decided to switch to a different carrier I need you to cancel and refund my method of payment please.
Payment
04-24-2024 09:08 AM
To clarify, we’re not employees on this site, we’re just other customers like you.
Prepaid services are non-refundable.
You can try you’re luck thru the contact info provided via @TheSterlinger , but don’t expect a lot.
Good luck!
04-23-2024 11:12 PM
You can try but chances aren’t very high. Use the small envelope button on the bottom right, sign in then type Cs agent and input the required information.
If the ChatBot doesn’t work then use this direct link. https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
