03-26-2017 05:42 PM - edited 01-05-2022 01:53 AM
Hi
I had change to a new plan,current I cannot make a call, need help!!!
thanks
03-26-2017 07:29 PM
Ensure you didn't forget to select a voice option when you changed your plan.
if you did forget, do not do anything, until you contact a moderator. Unfortunately, they're not in until 9 am tomorrow.
03-26-2017 07:19 PM
03-26-2017 06:57 PM - edited 03-26-2017 06:59 PM
Hi,
If you have done basic troubleshooting such as restarting your phone and calling still dont work, send a private message to one of the mod and they will get back to you tomorrow morning.
