07-25-2020 08:50 PM - edited 01-05-2022 12:16 PM
My SIM activated, phone number working, but mobile data not working
07-25-2020 09:15 PM
07-25-2020 09:14 PM
wowww, cool, changed APN, it worked! Thanks a bunch!
07-25-2020 09:00 PM
@bing_liang_Z yes that is the issue. Although Public Mobile is owned by Telus. You have to use Public Mobile APN settings.
See my first post.
Add those APN settings. Or edit your current ones.
07-25-2020 08:58 PM
hmm, some settings are slightly different,
my APN Name: TELUS SP
APN: sp.telus.come
so they are causing problems?
07-25-2020 08:56 PM
@bing_liang_Z for more targetted help. What's the make and model of your phone? Thanks.
07-25-2020 08:52 PM - edited 07-25-2020 08:54 PM
What is the make and model of your phone?
Check your APN settings. For Android phones try editing to this.
If they don't work try these
Save and reboot phone then try your internet.
You could also try simply resetting your network settings. A reset will erase your saved wifi connections ,etc.
If you used a referral code at sign up for a $10 bonus it will be applied to your account within 72 hours
Welcome to Public Mobile 🙂
