account no
Smithajoseph
How can I get the account no and pin
Jackhyf63
Your account number would have been e-mailed to you at the same time as your Public Mobile activation.  Also when you sign in your account,the overview page the top right shows your Public Mobile account number.if you forgot your pin ,you need sent PM to MOD.
sunflowershine
@Smithajoseph Seems you are new to PM. Welcome to PM! You need to set your account and your pin online.
You select the My Account and create an account. Follow the step and have your new SIM card ready.
Alex888
@Smithajoseph If you log into your account you can see your account number in the top right corner.. Your PIN should have been texted to you when you opened your account. If you lost it you will need to contact the moderators.
