09-06-2022 08:26 PM
I wanted to get 55 - 20 gig plan but computer automatically put me in as my old plan !!!!
09-06-2022 09:49 PM
What amount was paid? If you paid the $55 then try the little spinner refresh icons lower down. The caching of the page is terrible. Did you set the plan change for the next renewal?
09-06-2022 08:39 PM
Clear the cache, cookie and go incognito then login to your account then change your plan (dropdown menu).
09-06-2022 08:33 PM
don't worry contact PM support team by private message > CS_Agent
09-06-2022 08:30 PM
you need to contact a service rep they will fix you up
There are two ways to contact a customer service agent , open a ticket through Simon here https://publicmobile.ca
Or private message them here
https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user
