What is a Data Event
Bigpointguy
I was looking at my usage history this morning and see several lines that are called "data Event" as opposed to "outgoing call" or "web" etc.  It shows the orignating# and destination# as my phone number. Can someone tell me what this is all about. Below is entry.
thanks,
Pat
10/06/2019 11:15Data Event705*** ****705*** **** ON 1MMS$0.00
Bigpointguy
Thanks to both CellGirl and Tony8 for answering my question and solving the mystery.
Pat
Tony8
Hi. MMS texts use data at no charge.If you attach an image or group text it will be an MMS text message. Normal SMS texts don't use data.
CellGirl
@Bigpointguy
Hello. From your pic, looks like you sent a text message that included either a pic, video, or an audio file?  You weren't charged, so no worries 🙂
thanks,
Pat
It just means that cellular data and/or internet was used.
