Website Phone Compatibility Tool not working
McBob
The website's phone compatibility tool is not working; clicking to get the dropdown list of phone brands just drops down a blank single entry (Forefox 74.0 (64-bit)) I'm pretty sure my phone is compatible, since I'm currently using a SIM card (Koodo), but I wanted to make sure. My phone is an LG V10 (LG-H900; **bleep** you, AT&T for bypassing the bootloader!!)
2 REPLIES 2
McBob
Thanks very much. Although, I should note that willmyphonework.net's security certificate is expired, so Firefox threw me a big, obnoxious warning page. :cathappy:
GR
@McBob if it works on Koodo it should work on public mobile. You can check it on willmyphonework.net
