07-05-2019 10:26 PM - edited 01-05-2022 08:14 AM
Just want to be clarified because I am on the limited plan.
Any incoming calls get into my voicemail box will not cost plan minutes as long as I don't retrieve them, no matter how long is the message.
If I retrieve the message from voicemail, that duration will be counted as my plan minutes, i.e. listening for 2 minutes will cost 2 minutes of usage.
Hope my understanding is correct.
07-06-2019 12:30 AM
@ChuckYeah wrote:
Welcome to Public Mobile where things aren't quite so literal and exceptions abound. Some of the things in your image are not reality. But I guess they could change to become so. But this place works at a glacial pace to fix these kinds of things.
07-06-2019 12:25 AM
I know it is not a direct answer to the question, however it is a practical one. Long distance minutes cost $5/500 minutes. Let's not fret over a penny or two.
07-05-2019 11:55 PM
@guomao wrote:Just want to be clarified because I am on the limited plan.
Yes, this is correct as was mentioned in your other message thread. Someone leaving you a message does not use up minutes. That's why when it comes to your usage details showing outgoing calls to the voicemail deposit number wouldn't concern me. Your phone not ringing could have just been some strange quirk while the numbe porting was being completed.
07-05-2019 10:54 PM
@guomao If you doesn't want people to leave message at all, you can kind of disable the function.
07-05-2019 10:48 PM
07-05-2019 10:36 PM
07-05-2019 10:34 PM - edited 07-05-2019 10:36 PM
@guomao Yes your understanding is correct. If you don't want to use up minutes you can retrieve you VM s by dialing the PM main vm number from a landline or a wifi based calling app like Google Hangouts Dialer.
PM VM number area code 580-4001
07-05-2019 10:32 PM - edited 07-05-2019 10:33 PM
Callers dropping to voicemail do not cost minutes. Using a different phone to listen does not cost minutes.
Using the phone pressing and holding 1 (by default) will cost minutes.
Minutes are rounded up to the next minute.
