07-10-2020 10:49 AM - edited 01-05-2022 12:24 PM
1) I've noticed that Usage History shows regular outgoing texts to 7723. No charge or time is shown. This seems to be automatic. What is this?
2) Can I download Usage history for my own use, say in a csv, excel or similar file?
Thanks for your attention.
09-06-2020 04:38 PM
It doesn't seem like a very good solution. Will it stop SMS as a whole if Google Dialer is disabled? That's the concern!
07-10-2020 12:11 PM
Thanks.
I'll look at my settings and correct them.
07-10-2020 12:10 PM
Thanks.
I learn something every day.
07-10-2020 11:38 AM
@will13am wrote:@DanAR , I believe this is google dialer doing stuff in the background. It has been discussed in the past in this forum. If you disable SMS permission on the dialer app, this will stop.
@DanAR this is correct. It's the Google Dialer trying to configure Visual Voicemail, which is a service that Public Mobile does not offer.
There is no export available. Some have manually copied-and-pasted from the page to an Excel sheet. I believe someone was working on an automated way to "screen scrape" the info from the page, but I'm not sure that ever materialized.
07-10-2020 10:56 AM - edited 07-10-2020 10:57 AM
