Updating my Address doesn't Work
Faranaks
Hi I am to trying to update my address, but it is saying is not Valid.
@Faranaks
The system will use your new postal code for your location then enter your address and see if that works.
M8BAGGER
Good lord edit your post and get your personal information off the internet......
slusagm
Remove the address on your post, we are just customers here
Did you try putting the address slowly and let the system auto lookup?
Or as PM to help. Just open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA when login, you might need to use email to receive if you cannot receive the text on the phone.) Type the question Submit ticket and select Contact Us to get to ticket open screen
Or message them using this link:
