Unable to make calls
sharathks
@Moderator_Team
Unable to make calls from my mobile number
msromeo
Does it just not call or do you get an error message?  If you ported over your number it may still be activated with your previous carrier.  Happened to me with Bell.  I ported my number over and texting worked immediatley but could not call or receive calls.  Once I cancelled my old plan with Bell with the same number, I could then use the PM phone perfectly 🙂
CS_Agent
Customer Support Agent
sharathks
Tried to restart, pull out and put the SIM back, not working.
Just stopped connecting to network.
Dunkgirl
@sharathks wrote:
@Moderator_Team
Did you just port over ? What happens when you try to make a call? Does MMS work? Does SMS work? Can someone call you? Are you connected to the network? Have you pulled out your sim card and put back in? Have you tried anything to remedy the situation? If so what steps have you done?
darkstar107
Does anything else work (receiving calls, SMS, data)?
You'd probably be better off send the mods a direct message rather than just mentioning them.
