US Roaming -
hung52
I would like to ask if I purchase the Data Add-on (1Gb) + US Talk, I would be able to make calls to Canada and receiving call from canada while im in US right?
@hung52, you shouldn't need to change your settings.  Make sure you have your Data roaming turned on.
hung52
Ok so after I purchase the Add-on, do I need to change something in the API Data? im worried if it will not work... What are the step to follow if the Data isn't working in US?
Chaos_Scorpio
You'll know you have it once you go to your summary page and it shows the addon is there.
keep in mind the day you buy is the day it starts.
NDesai
Correct Smiley Happy
FYI, Purchasing add-on is a two step process. First time it will add funds to your account. So, you will need to buy that again and this time it will use funds you added to add the add-on to your account.
