03-28-2018 06:52 PM - edited 01-04-2022 03:48 PM
Hi there,
I have a question about adding an Add-on plan while traveling to USA for about a week.
My wife and myself would like to add a US add on to be able to Talk and Text (unlimited within US and Canada), and some data (1GB).
Which add on or add ons do we need to select to cover this.
Thank you very much,
03-28-2018 09:07 PM
@watsonWhen my wife and i went away for 14 days I bougt the talk text and data plan (250) mb and she bought the talk and text a 4 days later. depending on your actual needs you both might not need the same plans.
also one way i saved lots of data was downloading google maps for offline usage while you are on wifi and tutning data off when i did not need it.
another option is get 1gb data only and use a voip service like fongo and forward your call to fongo.
03-28-2018 08:31 PM
@watsonwrote:So does this plan "US Roaming - Talk Text (10-day) - $15.00" cover calls from US to Canada or just to US numbers while I'm in US.
Cover calls from US to Canada & US
03-28-2018 08:13 PM
03-28-2018 07:57 PM - edited 03-28-2018 08:01 PM
@watsonwrote:
03-28-2018 07:50 PM
@watsonwrote:when i log into my account I don't have the option for U.S. Talk and Text Bundle (Unlimited Talk and International Text for just $15 for 10 days). There is no such option.
It is visible when i'm not logged ; https://www.publicmobile.ca/en/on/plans
I'll try to post my options of add-on in a minute
It is listed on the right. I copied the name from the main site but i realized that it is named different in the self-serve where you actually purchase the add-on.
03-28-2018 07:38 PM
03-28-2018 07:30 PM
I have seen that advertised somewhere...
03-28-2018 07:26 PM
03-28-2018 07:10 PM - edited 03-28-2018 07:12 PM
@watson You will need to select US Roaming - Talk Text (10-day) - $15.00 and US Roaming - 1 GB Data (10-day) - $20.00.
