UK roaming
Mdeloug
Is there away to add roaming to my public mobile plan?
About 1 month from now I'm going to be in the UK for 5 weeks but I want to stay connected to via my regular cell number.   Any way to do this?
T.I.A.
Mdeloug
That's helpful.
Thank you.
HALIMACS
@Mdeloug
You might be better off purchasing a local prepaid sim card while in the UK.
dust2dust
Not for the UK.
You could get a voip app like Textnow and forward all calls to it. With some more work you can also forward texts. But then to call back or reply would be the voip number and not your Public number.
