08-16-2020 03:06 PM - edited 01-05-2022 12:48 PM
I've been on Public Mobile for over a year. All was well until I got a new phone last week. Everything works except two apps only work on WiFi - they will not connect with mobile data. I've tried all the suggested solutions I can search out. The new phone is a Moto G8 Power with Android 10. All apps work on mobile data except my two security camera apps. They just say "connecting", but never do. In settings for Android 10, I've made sure Background data is ON, and Unrestricted Data is ON for the two apps. I've also made sure Power optimization is turned off for the apps. I've tried a few suggestions on Android forums and sites, but nothing helps. I've tried removing my Google accounts and re-adding them and yes, I've tried rebooting the phone. I've tried clearing caches where suggested as well.
I'm in Ontario, and my APN settings (which set up automatically) are:
APN: sp.mb.com
PROXY: Not set
PORT: Not set
USERNAME: Not set
PASSWORD: Not set
SERVER: Not set
MMS PROXY: mmscproxy.mobility.ca
MMS PORT: 8799
MCC: 302
MNC: 220
AUTHENTICATION TYPE: Not set
APN TYPE: default,mms,agps,supl,fota,hipri
APN PROTOCOL: IPv4
APN ROAMING PROTOCOL: IPv4
APN ENGABLE/DISABLE: APN enabled
BEARER: Unspecified
MVNO TYPE: GID
MVNO VALUE: 4D4F
03-25-2026 09:02 PM
I have the same Problem. since i switched to eSIM, it was working fine before (with physical SIM)
08-16-2020 05:41 PM
Thank You! It worked - much appreciated.
08-16-2020 04:55 PM
Then try using the APN settings that I gave you.
08-16-2020 04:54 PM
@Avy to reset your network settings
open settings
scroll down to system
tap on reset options
tap reset wifi,mobile & Bluetooth
tap reset settings and restart
leave the APN settings alone when you do this reset and then test
08-16-2020 04:51 PM - edited 08-16-2020 04:54 PM
Tried clearing the cache for the apps - no change
Uninstalled the apps, rebooted the phone, installed the apps again - no change
When you say "resetting your network settings", I'm not sure what you mean. Do you mean the APN settings? I tried the settings suggested by gblackma, but no change.
08-16-2020 03:18 PM
@Avy try changing to these APN settings below
APN settings:
APN: sp.mb.com
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMS proxy: 74.49.0.18
MMS port: 8799
MCC: 302
MNC: 220
Authentication type: Not set
APN type: Not set
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: Not set
MVNO value: Not set
08-16-2020 03:16 PM
@Avy try clearing the apps data and cache. otherwise uninstall the apps restart your phone and then reinstall the apps again
try resetting your network settings
