Trouble finding a phone
kelem
When I search the Public website for phone compatibility, I can never find an exact match based on what unlocked phones are available for sale.  For example, the website has a listing in the drop down for a Samsung A10, however, when you search it only lists sub models, such as SM-A105F (Global).  The only A10 I can find for sale is an A10s.  Everything I search seems close, but no cigar.
yumyum
Try buying a phone off Best Buy or amazon then taking it into a store to get your SIM card and plan
The A10s will work, it has the required 3g bands. @kelem if its one of these 2 varients https://www.gsmarena.com/samsung_galaxy_a10s-9793.php its LTE bands are a little light. No band 4. Stay safe.
benfatto
@kelem  In addition any phone that works on Telus/Bell will be compatible. All phones must unlocked except those from Telus/Koodo.
gpixel
@kelem hi your phone is compatible with pm. that phone list isn't updated regularly
